Optimistic_Para
Oct 31, 2018Explorer
That's correct. The Tow/Haul button is an on/off switch. Hit it once, it's on, hit it again, it's off.
Ford, GM, Ram, and even Toyota have "tow/haul". The features are not necessarily identical. They all change the transmission's shift points to better match both pulling heavy loads, and provide better engine braking. Some may also lock out the overdrive and/or lock the torque converter.
If you're running in tow/haul mode when you AREN'T heavy loaded, you won't hurt anything, but you probably won't get as good a gas mileage as you would without it on.
Original Poster has a Winnebago. Just off hand, I don't know whose chassis that's built on. Ford? GM?
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 06, 2026
