- luberhillExplorerSo you have to push the button AND tap the brake twice ???
- Artum_SnowbirdExplorerI have almost the same rig as you. You want to go down a hill at a comfortable speed without braking. Tapping the break puts the transmission into a lower gear, the engine rpm's speed up and the result is more drag and less speed.
Try pushing the button on the end of the shift lever next time you go downhill then press the breaks. It will become apparent immediately.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
