wnjj
May 31, 2021Explorer II
Jframpey wrote:
I disconnect- Chevrolet stays hot with ignition switch off (at least 2008 Silverado). Why take a chance of draining my vehicle battery? What if the converter quits, power outage, surge?
If you’re going by risk, there’s a greater chance a pin will break off in the 7-way connector when you go to plug it in than a power issue affecting your truck. Even if the shore power failed, you’d have to run enough 12v loads to drain your trailer and truck batteries.
In our case it’s a truck camper and there is no option to unplug until it’s partially lifted up.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
