txbassmn's avatar
txbassmn
Plugging in to shore power
Just curious about something. When you get to your spot how many people turn the breaker off before plugging in and then turn it back on after you have plugged in, and how many just plug in without touching the breaker. I usually turn the breaker off before plugging in, but I have at times just plugged in not thinking.
  • CloudDriver wrote:
    - If breaker off, turn on, plug in circuit tester
    - If circuit tests OK, plug in SurgeGuard
    - Plug shore cord into SurgeGuard
    - After 2 minute time delay SurgeGuard supplies power to RV
    - When disconnecting, turn off A/C loads in RV (A/C, microwave, etc.)
    - Turn off breaker, disconnect shore cord and SurgeGuard
    X2. that's the best way. I have several of those little yellow plug in testers and the appropriate adapter cords. I also keep one of those inexpensive voltage meters plugged in to the socket in front of the sink.
  • I have a Progressive Industries EMS protection system so I just plug in without worry. The power is off until it is verified stable with correct polarity and voltage.
  • - If breaker off, turn on, plug in circuit tester
  • Thats what makes the receptacle go bad. You should always shut it off first.
  • I always turn breaker off. It prevents surges when you insert the plug. My electrician friend says it's the only way.
  • If the breaker is not already off, my first action before plugging in is always to turn it off. Always...
  • I turn off the breaker and also check the socket (30A in my case) for wear and overheating damage.
    I have also asked for a different site if the socket is in poor (loose) condition.
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
