DandM-AG's avatar
DandM-AG
Portable Waste Holding Tank
Hello All
I have a 32 gallon portable wastewater tank for use when the park has no sewer hook up.
Question is: when the 3" waste gate opening on the RV is lower than the opening on the portable tank, how do you empty your RV tanks when you typically rely on gravity?
Any suggestions would be much appreciated.
Thanks,
Mark
  • I own a 42 gallon Barker blue tore. I attach a hose to hit and connect hose to dump station connection. Generally the dump station inlet is flush with the ground and lower than the tote. As the tote empties, you can lift the entire tote higher if you need to create more fall.
    Don't over think it. It's really not that complicated
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
