Frank55
Sep 29, 2017Explorer
Portable waste tanks
I see the 4 wheel waste totes and the 2 wheel totes are a lot cheaper. Are the totes worth it and is the 2 wheel tote an option to save a litte money?
DutchmenSport wrote:
Can you lift it. Putting a 7 gallon jug in the back is my truck bed is NOT an option.
Over spilling "poo" on the ground at the campsite is absolutely NO fun!
Ron3rd wrote:It beats waiting in line at the dump station!
I've found my Barker 32 gallon tote to be invaluable over the years with a wife and 2 daughters taking showers with no hook-ups. It's a minor hassel to me but well worth the effort to be able to dump the grey tank..
Lantley wrote:SoundGuy wrote:
For me, a wheeled tote tank proved to be the biggest waste of $$$ mistake I've ever made since we began RVing years ago. :( Costly, heavy when full, still heavy when empty, awkward to clean thoroughly so it doesn't stink, takes up too much room in the truck for transport, looks ugly hanging off the back of the trailer, is awkward to store out of the way at home, and always threatened to pop off the hitch ball as I towed it over bumpy campground roads. :M It only took a few trips before I realized the error of my ways and sold it to another unsuspecting RV owner who also thought this would be his answer to waste water management woes. With the proceeds I bought a FloJet Waste Macerator so I can service my tanks here at home but anytime I may find the need to off load black water while camping I can pump it with the macerator into a few inexpensive 7 gal Aquatainers labeled for GW/BW use that sit in the back of my truck, for a later trip to the dump station. Grey water I usually don't even bother with the macerator but simply gravity feed it into those same GW Aquatainers. K.I.S.S. - no tote. :)
Funny my experience has been the total opposite. I sold my old 4 wheel 32 gallon tote on Craigslist and purchased a 42 gallon tote with pneumatic wheels.The 42 gallon tote works great and is easy enough to handle
I can carry it on my rear ladder. AS far as looks beauty is in the eye of the beholder. The tank is a tool for dumping it's not a work of art.:S
I also have a flojet macerator that I seldom use because it takes too long. The flojet work as designed but dumping through a 1" hose takes a lot longer than the 3" stinky slinky
Dick_B wrote:Gray water and a bit of dump station water clean it just fine. Rinse off the outside, put the caps back on, and no stink.
..I would never put black waste in a tote. It would be impossible to clean it adequately and where would you store it where it wouldn't smell up the surroundings.
Dick_B wrote:
two comments: water weighs about 8 lbs per gallon and I would never put black waste in a tote. It would be impossible to clean it adequately and where would you store it where it wouldn't smell up the surroundings.
Lwiddis wrote:
Where will you dump your tote? Hopefully not in the outhouse or chemical toilet provided at many USFS CGs.
mowermech wrote:
I had a 2 wheeled waste water tote once.
I realized that anyplace we went either had full hookups or no dump station within 10 to 20 miles.
