mileshuff's avatar
mileshuff
Possible damage to water heater if bypassed while on?
Brand new 5'er. Turned electric and gas on to heat up water. Couple hours later found no hot water. Checked breakers, propane etc. and all were fine. Figured heater must be bypassed. Checked and sure enough, dealer had left valves in bypass mode. Fixed that issue and heater tank filled. However, pressure relief valve was wide open pouring water out as fast as it came in. Water was cold at this point and no actual pressure existed. Replaced pressure valve and water now heats as it should.
Question is whether any damage could have occurred to heating element or anything else? Could a tank of hot air have caused the relief valve to fail and stick wide open?
  • Hope you let water heater cool way down before filling it with water....
    Atwood uses an aluminum alloy tank...it can take the heat
    Suburban uses a steel glass-lined tank. Porcelain could have spider web cracks which will cause issues later on from steel tank rusting
    Electric element....they need to be submerged in water. They burn out quickly if run dry
    Propane operation......most likely was shut down by high temp t-stat opening (180*f)
    PRV....increase in pressure from air heating and the hot air caused it to fail
    Got overheated. Best that you replaced it.
    Always check that water heater is full before turn it on.
    On Edit: Oops...maybe I shouldn't have posted :S
    Don't know about the hot air/valve open deal. Anything is possible.
    Try running heater on electric only, see if it works correctly. Let it cool and see if it works correctly on gas only. Check for leaks. No problems, good to go.
  • it only takes a minute to ruin an electric heating element if there is no water in the tank. I am surprised you didn't burn a hole in the bottom of the tank with the water missing and the propane on and burning. it is the water in the tank that keeps the tank from melting. you may have done some serious damage to your tank. I think I would have it checked out.
  • If there's water in the tank then it should be fine. But it takes just a few seconds when empty for it to destroy the electric element.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
