bid_time
Feb 22, 2016Nomad III
fj12ryder wrote:You disengage the motor and roll it in. Quite similar to what you would do if the spring broke in yours. My recommendation though would be for you not to buy one, you clearly have a preconceived bias. The OP's question was "can you...", the answer is: yes.wing_zealot wrote:And if the motor is shot?Retired JSO wrote:Not really, simply two jumper wires and a battery.
Carefree and Dometic power awnings require an act of congress and an RV tech to use manually.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 31, 2026
