Deb_and_Ed_M
Nov 29, 2014Explorer II
DutchmenSport wrote:
Not knowing how far back the main power cord is damaged, if it were me, I'd simply pull the cord up through the inside of the box past the last bad area. Then cut the cord, strip the wires, and then just re-attach in the metal junction box. Simple, but it will shorten your on-board cord.
I thought about putting a new plug on the end of it (the damage is from the middle, out to the plug) - but in cold weather, stuffing this cord back into the "mouse hole" is a real nightmare (pulling it out isn't easy, either); plus using the marine outlet doesn't provide entry for the rotten little critters. I'll just jam steel wool into the old mouse hole.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
