Deb_and_Ed_M
Dec 05, 2014Explorer II
OK - world's slowest repair job....LOL! Today, I located a spot for, and created the hole for the Marineco fitting. I wasn't planning on mounting it this high; but my stud finder kept telling me there was something "solid" immediately below this point and it ran all the way to the floor. This spot is fine - it's still inside the little compartment disguised as an end table at the rear corner of the 5er. The new plug location is at the top of the pic.
This is a darn fine hole! I cut it using my Skill saw. I'm too cheap to buy a hole saw/arbor for one use.
And that's it for today. I wasn't anticipating my walls being almost 2" thick (pleasant surprise!), so now I need to go to a hardware store for some long skinny bolts. Since my wall is basically 1/8" plywood sandwiched over foamboard - and I just KNOW Ed is going to walk up and try to pull the plug out without unscrewing it.... I want bolts with washers, or else it's going to get yanked out of the side of the 5er at some point or another...
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
