4x4van
Mar 05, 2018Explorer III
Is the TT sitting by itself, or do you have your tow vehicle? If so, then just hook it up and run your tow vehicle to charge your TT battery. If not, then I'd try the tractor first. Check your battery voltage with a multimeter and verify that the voltage increases when hooked up to the tractor (running). It may not be fast, but would probably be sufficient. No need to buy another generator.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
