DrewE wrote:
dedmiston wrote:
If they wanted to limit you to the 30A receptacle, then they wouldn't also provide a 20A receptacle.
Actually, the National Electric Code requires that every site with electricity have the 20A receptacle (even when there is also a 30A and/or 50A receptacle). I assume this is at least partly to cut down on people using 30A to 15/20A or 50A to 15/20A adapters which frequently do not have proper overcurrent protection--and, presumably for that reason, are also frequently not UL listed.
I agree that it is perfectly within one's rights and reasonable use to plug things into both the 30A and the 20A receptacle, unless the campground specifically requests otherwise. Using the amenities that are included with your campground fees is perfectly reasonable--I don't see where it's any different than using the playground or swimming pool or nature walk, even if not everybody who camps makes use of them; it's part of the package deal for getting the site.
I use a good quality small electric grill for outdoor cooking. I always plug into the pedestal 20A receptacle for this use. Would the nay sayers be happier, if I plugged into my FW outside receptacle? IDK, but direct power from 20A receptacle, just makes more sense.
Jerry
