ken56 wrote:
Bobbo wrote:
ken56 wrote:
All the amp designation is is the limit of amperage that you can draw from that receptacle. You don't add them together though it should be possible to draw 20A from that one and 30A from the other one without popping either of them.
Almost but not quite. The amp designation is the limit of amperage that you can draw from that BREAKER (not receptacle). If the 20 amp breaker is fed off of the 30 amp breaker, the 30 amp breaker will pop if the combination of both outlets together exceeds 30 amps. Wiring that way is within code.
Only a lazy or dishonest electrician or an amateur would wire it that way, ........
Or an electrician being paid by a campground owner who wants it wired that way. You are right. I did understand what you meant. Then, I clarified it to make it accurate. Have a good day.
