redetorok's avatar
redetorok
Powering an Oxygen Concentrator
Hey everyone:) I have a Caire Companion Eco Oxygen concentrator that I use mostly at night when I am sleeping. It has a 350 watt maximum rating. Although I have a 4000 watt generator onboard I don't want to run it for prolonged periods of time so I am looking for some input on how much solar power would be needed to run the concentrator and perhaps even a toaster or some other small low wattage appliances. But am mostly curious about the concentrator. There is a 100 watt solar panel mounted on top of my Class C but I am sure that it won't be enough to do what I want it to do. So any help would be greatly appreciated.
!. How many additional panels will I need?
2. What wattage should they be?
3. What size of an inverter should I use?
4. What would be the best controller to use with the system?
  • On the other qx,
    Inverter? you would want at least one rated for 400 watts continuous, 600 watts would be better. And it should be a pure sine wave inverter.
    Not recommending any of these, just examples, inverters
    On the controller, you may find it easiest to get a kit from a company such as Renogy which would have the controller included.
    If you are going to have a total of 400 watts get at least a 40 amp controller to allow an extra panel or two in the future if needed, without having to change the controller.
    Examples, solar kits
  • If your insurance is paying for you concentrator, ask your provider about switching to a portable battery operated model like one of the Inogen One models. The G3 for example, only draws 10 amps using the 12-volt power cord and with their rechargeable double battery runs 10 hours on a charge.
