John___Angela
Jul 11, 2014Explorer
Good morning.
Two things. To precool a residential takes a fraction of the time so a ciuple things may work for you.
* Can you bring power to the rig when parked outside of the house. You don't need much in the way of current. Eg...no 30 amp needed.
* Do you have a small generator you can run for an hour or two the morning of
* Can you install an inverter. Fairly simple if it is just dedicated to the fridge.
Tell us a little about your rig. How many batteries etc.
The fridge won't use any more than a flat screen TV so its probably considerably less than you think. Even a couple of 6 volts will run a fridge for a day. But like I said they don't have to run long to get cold. An hour tops.
Hope this helps.
Hope this helps.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
