austinjenna's avatar
austinjenna
Pre cooling a residential fridge
For those of you that have one in your rig, what do you do to pre-cool it? I have the standard 3-way fridge now and go the night before and fire it up on propane. We have been recently looking at some new rv's and a lot of them have the full size fridge in it. I am curious as to what folks do.
Mine is in a storage yard so there is no access to electric. I would think with an inverter it would drain that battery pretty quickly.
  • Ours cools down in less than hour. Considerably faster than any RV absorption fridge. It starts cranking out ice in minutes.
  • Just to be clear, you are looking at a new rig with residential electric-only fridge? Or, a full sized 2-way (electric & propane) fridge?
    If electric only, you could throw in some a several frozen water bottles, bags of ice or similar when you turn it on the night before. I have no idea if it would cool down enough to be beneficial. The nice thing about using frozen bottles is the water is contained as ice melts.
  • Plug it in and wait 1/2 hour. If you want to run a 120V fridge without connection to shore power, you'll need an inverter and more than one battery (if you plan to run it for a day or so).
  • YEs your would have to turn it off. It cools down pretty fast but that being said I can only tell you from the time they plugged it in when they were installing it till the time I was backed into my spot I had one tray of ice dump.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
