Bill_Satellite
Oct 19, 2013Explorer II
There are 2 pieces to the puzzle.
1) The hose from the faucet to the RV.
2) Holding tanks inside the RV.
My personal recommendation is that anytime the outside temps are expected to be below freezing you fill your holding tanks, disconnect and drain your fill hose and turn on your water pumps. That's all that needs to be done if the temps will be in the 30's.
If the temp is expected to be in the 20's or below then you are likely going to need to provide to your holding tank are as well. Most RV's are setup such that the coach heat also heats the tank area. You need to verify that yours does or does not. You can also add small electric heater in that bay if you have the room and connections available and there are electric heat mats which can be installed if you are looking for ways to avoid turning on the propane heat (making an assumption here).
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
