Community Alumni
Jul 01, 2013Not applicable
I have the Pressure Pro system also and it is 6 years old. There is a seal in the end of the sensor that screws onto the valve stem. This seal is removeable and can be replaced. I remove the sensors in the winter when I am not traveling to save the batteries. I found that removing and installing much can wear the seals. I replaced all of the seals last year and have not had any issues since. Call Pressure Pro and talk to them as I found them very helpful.
Also, I question using the sensors with extenders as it seems this could cause issues with sealing the valve stems.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
