gbopp
Jan 18, 2016Explorer
B.O. Plenty wrote:
I doubt you will ever get rid of that mess. If it was mine, short of replacing the entire roof, I might try cutting that section out, gluing down a new piece of rubber roof material, then sealing all the edges with Eternabond tape..
B.O.
X2. That may be the easiest and best way to make the repair.
You can try a heat gun and plastic scraper but, it probably Will be a major mess.
I would cut out and replace the bad area.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
