j-d
Jul 29, 2014Explorer II
Driveshaft is actually tubing, and fairly thin wall at that. So anything hard that jars it will create a Ping not a Clank. We bought a Frontier with manual transmission to avoid a Disconnect/Lube Pump scenario. Not even 4x4 Frontiers with automatic are towable since there's no Neutral in the Transfer Case.
Cleanup/Tuneup should solve it. A lot of the problems also seem to be the Cable. Either sticky or installed with a kink or tight bend.
I've always thought that if I wanted a Drive Shaft Disconnect, I would first buy a junkyard driveshaft. Have IT tuned up by a driveshaft shop and the disconnect installed in it. Keep my original for resale or a rainy day.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
