popeyemth
May 26, 2013Explorer
Propane gauge
Our new to us Shadow Cruiser truck camper has a single 20 LB propane tank Has anyone found a reliable tank gauge so we know in advance its getting low? Any I've heard of when they indicate low you a...
ChooChooMan74 wrote:FYI: PHMSA Emergency Recall of all Lite Cylinders.
Try litecylinder. They are $100 and are lighter and you can clearly see how full they are
On May 24, 2013, The Pipeline and Hazardous Materials Safety Administration issued Emergency Order Number 2013-002 mandating a recall of all cylinders manufactured by The Lite Cylinder Company, Inc. (Lite Cylinder), Franklin, Tennessee, and marked as authorized under DOT-SP 14562 (and DOT-SP-13957 as authorized therein), DOT-SP 13105; any cylinder requalified under H706, and any cylinders manufactured under M5729. This recall order also applies to any person who is in possession of an affected packaging that is subject to this order.
The emergency order is based on an investigation of Lite Cylinder’s operations and production history that revealed probable violations and unsafe conditions and practices that PHMSA determined present an imminent hazard to the public safety. In effect, this action immediately orders the removal from service of more than 55,000 two-piece fully wrapped fiber composite cylinders. These cylinders are largely in liquefied petroleum gas service.
PHMSA also terminated the above special permits and approvals for cylinder requalification, and manufacturer’s Registration Numbers.
