AirZone's avatar
AirZone
Propane line
Has anyone installed a high pressure quick connect alongside the low pressure. If so how? I thought that might be easyer than converting all the appliances we have.
  • I have a portable tank with a "Y" and 2 shut off valves. These feed 2 hoses that have a connector on the end just like the portable tanks. This allows me to run my portable grill, stove, lantern, and heater from the portable tank. I can run 2 appliances at a time; 1 from each hose. I've been using the same set up for about 20 years with no problems.
    I think the hoses and "1 pound tank fittings" came from Mr. Heater. I got the "Y" fitting and valves at a welding gas supply place.
    I would think the same thing could be done to the tanks on the RV. Just put a "T" into the line between your tank and regulator. Add a shut off valve, hose, and the fitting on the end to match the throw-away tanks.
  • If you want a high pressure line to use your bottle grill with, it is not necessary. Go to your local RV dealer and buy a kit to convert your grill to use the low pressure line on you RV. The kit consist of a long gas line to keep the grill away from the RV when using it and a low pressure regulator to replace the high pressure regulator for the bottle.
  • charwan wrote:
    Why would one want that and what would you gain by having one????? Never heard on any thing running on tank pressure (appliances)? Just asking.
    For bbq's , propane heaters and propane lanterns that have a regulator built in. Appliances won't work with 2 reg's in line.
  • Bobbo's avatar
    Bobbo
    Explorer III
    You can't install a high pressure outlet "alongside" a low pressure outlet. The high pressure outlet must be before the regulator, and the low pressure outlet must be after the regulator.
  • If this for your Coleman trailer, an easy connection is an Extend-A-Flow tee mounted at the tank. Believe they come with 12 foot line.
  • Why would one want that and what would you gain by having one????? Never heard on any thing running on tank pressure (appliances)? Just asking.
  • My coach has a high pressure connection curbside. The connector is a 1/20 connector (same as the little green bottles) and a low pressure quick connector. Both have shutoff valves before the connectors. I dont know if both were factory or just the low pressure.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 26, 2026
