ENG2242's avatar
ENG2242
Propane of Electric to heat H2O whilst Full-Time
I live full-time in my 5th wheel. With that in mind, do you guys use propane or electric to heat your water.
Suggestions and why please.
Thanks guys,
David
  • Gee beemer my response on the same issue...double posting...was deleted!
  • rhagfo's avatar
    rhagfo
    Explorer III
    We full time and use both! Gas for fast recovery and electric to help maintain. We
    Both shower almost daily, wash dishes, and cook with gas, and don’t think we use 7 gal a month.
  • If electricity is included in the cost of the site...of course use electric (assuming you have enough amps).
    If you are trying to run the air/con or the electric is charged per KWH and is excessively high priced, then consider propane.
    Another thought...if you need hot water quick or you are using a lot of hot water, you typically can run both at the same time and it will heat much quicker.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
