hybridmom's avatar
hybridmom
Propane Question
I have 2 20lb tanks on my 17 ft. hybrid. We don't like cooking inside the trailer and would like to be able to run a hose to the side of the trailer from the tanks, or one of the tanks to use on the stove.
How can I do this? The two tanks are currently attached to a splitter with the knob to pick which side you want to use first. I have been just disconnecting one side but I notice that some propane escapes until the pressure is up in the hose and sometimes takes a few minutes so it doesn't seem too safe. Is there a way to cap that side. We don't camp for too long at a time so I'm ok with the trailer only having access to 1 tank.
Can I remove the second pigtail and cap it somehow? Or any other idea is appreciated. Thanks.
  • downtheroad wrote:
    This>>>>>***Link Removed***
    Thanks! I don't quite understand how this works. Does it attach between the pigtail and the 20lb tank? And then the capped end is for the extension hose?
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Jan 24, 2026
