- BrownleafExplorerMugirardo, it is a chrome book so just using a keyboard. Just now I typed an M and it wanted to jump back to the front of your name. On a previous post I hit the insert sign above the 6 and it deleted the whole paragraph that I had written. if getting a new chrome book eliminates these problems For Good I will do it. Doug
- mgirardoExplorer
Brownleaf wrote:
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing.
Assuming this is a laptop, keep your palms up when you type. It sounds like part of your hand is swiping the mouse pad as you type and causes the cursor to move, possibly selecting text. Then when you type the next letter, whatever text was selected gets deleted. You can also buy a desktop style keyboard (wired or wireless) and you won't have that problem anymore.
If going wireless, might as well get a keyboard and mouse combo, then you don't have to use the laptop's keyboard and mouse pad. Some laptop mousepads are a real hassle.
-Michael - BrownleafExplorerAll good info. i did use the furnace this winter to avoid too low temps in rv. It seemed like the propane emptied out faster than last year. Good idea on disconnecting while doing rust removal and repainting of tank. Doug
- Grit_dogTrailblazer
Brownleaf wrote:
Grit dog, gennset was removed but drive could have caused it. So even if it is opening on its own, you are saying the leak detector going off is a down system issue. The tank is basically empty right now. If there is a tiny amount in it would it be unsafe to try a stove top burner? And in fact should I open it up to see if that leak detector comes back on? Doug
Presumably the leak detector is inside the camper and the valve/tank is outside, open to the air? Yes, a leak, if there is one, is likely downstream of the valve on the tank. (That could be leaking too? but not likely detected inside).
Since you're planning/needing to do work to the tank/valve it seems, I'd see what's left in it.
Turn it on and try to fire up the stove is a good way to tell.
FWIW, one can smell a very small amount of propane, but the concentration would have to be a major leak or leaking a long time and not vented to get to be enough to explode.
Or just unhook the line after the valve and vent/run out any residual gas in the tank. No smoking! LOL
I thought you had been using it regularly. My bad
You need to empty it anyway if you're doing rust work. and once it's empty you can easily replace the valve if it's giving you problems.
(I say easily, but I'm used to working on about anything that needs built or fixed, so idk what your comfort level is) - BrownleafExplorerGrit dog, gennset was removed but drive could have caused it. So even if it is opening on its own, you are saying the leak detector going off is a down system issue. The tank is basically empty right now. If there is a tiny amount in it would it be unsafe to try a stove top burner? And in fact should I open it up to see if that leak detector comes back on? Doug
- dedmistonModerator
Brownleaf wrote:
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing. I live alone and know little about computers. I say all to explain why I am not more verbose about issues. I may have bigger issues with my lp system. I am still checking to see if the valve closure was an error or it takes weeks to slowly open on its own. my 04,24 ft winnie stays in my driveway and I like to drive it once a week. I am doing various proejects such as recaulking and now rust removal from undercarriage. Doug
Hang in there Doug. - Grit_dogTrailblazerSorry, that makes a bit more sense.
I've never seen a propane tank valve that vibrated open, so it seems kinda strange.
Would think that is only possible when driving/vibrating. Maybe onboard generator causing vibrations?
Take this advice with a grain of salt, but if it's actually opening on it's own, I'd safety wire it if you continue to use it. - BrownleafExplorerGrit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing. I live alone and know little about computers. I say all to explain why I am not more verbose about issues. I may have bigger issues with my lp system. I am still checking to see if the valve closure was an error or it takes weeks to slowly open on its own. my 04,24 ft winnie stays in my driveway and I like to drive it once a week. I am doing various proejects such as recaulking and now rust removal from undercarriage. Doug
- Grit_dogTrailblazerDude, if you have to close the valve at the tank to prevent it from leaking somewhere downstream, you have bigger, more dangerous issues.
But then again, alot of what you are saying doesn't exactly make sense, like now not winter, so not using propane?
You obviously have an old moho, which presumably has other LP appliances (water heater, fridge, stove?)
And you are presumably camping or living in it, as your question(s) relate to active use of the camper, so to say the least, you leave alot to the reader's imagination as to what could be or is actually going on... - BrownleafExplorerSkibane, i was sure i had turned it off and came back later to find it open most of a turn. I THINK this happened twice. However, since I last closed it all the way this has not repeated. i will just have to keep checking it. I am not using it now but in the winter it seemed like the propane was being used up fast. i did have some beeping on a very old leak detector relative to this recent discovery of the partially opened valve. Either I was careless or it opens on its own gradually. i definitely will be getting a new kidde multi gas detector soon. Doug
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
