- Matt_ColieExplorer II
steveh27 wrote:
Matt_Colie wrote:
I had to replace mine and the part was about 80$us and shop didn't change me any labor, but I would not count on that.
Matt
Matt, Where did you have that done? We are close & I may need it.
Steve, I contacted a nearby bulk propane supplier. Bad news right up front, the company changed names and won't deal with me anymore because I am not a fixed tank customer. I had to remove the tank and bring it to them for them to do the valve swap. I don't know where to send you now.
Push comes to shove, you can try Cinnabar in Sandusky MI. They are up in the thumb and they work on motor homes.
Matt - SkibaneExplorer IIIs the valve handle actually turning on its own, or is the fully-closed position changing over time?
- Grit_dogNavigator III
Brownleaf wrote:
On my motorhome ( perm. tank), I discoveed that my shut off valve opens back up partially after having been closed earlier. Is this an easy - simple relacement? Expensive? Doug
Would this be the same LP tank that you couldn't get filled, too rusted out, scenario form a couple months ago? - steveh27Explorer
Matt
Matt, Where did you have that done? We are close & I may need it. - BrownleafExplorerThanks, will pursue. Doug
- Matt_ColieExplorer III had to replace mine and the part was about 80$us and shop didn't change me any labor, but I would not count on that.
Matt
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 20, 2025
