atwowheelguy wrote:
I don't know it I can make 15" of space to accommodate the poly hard case. I'll look tomorrow. It's just about too cold for me to work outside for more than a few minutes.
Realize the dimensions aren't quite accurate there. The Camco basically needs 1" off your tanks forward and rearward to fit - that's about the depth of the corrugations in the plastic profile that give the cover a friction fit to the tanks and provide rigidity to the cover. There is a mild bulge-out at the top of the cover in the center, both side, but would likely be above the top of your jack with 30# tanks (mine is). If needed, and what I have seen folks regularly do to fit around tall WDH hangers like Equal-i-zer's, you can easily notch the plastic out. To fit between my tongue jack - stupid Lippert design with the enormous plastic head not unlike yours - and my WDH brackets, all I have to do is gently pinch the cover in when I put it back on to slip behind the bracket. On my prior TT where I had an UltrFab tongue jack and replaced the original PVC cover that gave it up after 7 years, the Camco fit with inches to spare! :B
