F450's avatar
F450
propane tank purging
Have anyone ever had their propane tank purged? I was reading in the FMCA magazine that it should be done once in awhile.
  • To the best of my knowledge. There is no need to purge unless the tank ran dry and the valve was left open so air could get in.
  • Before first fill is all that is needed.
    Propane cylinders are typically shipped with air
    That air needs to be purged.....air mixed with propane will cause popping noises/regulator issues etc.
    Purging can be done using:
    Propane Vapor (purge kit with supply cylinder and purge valve) Vapor is transferred 4-5 times in and bled off to remove air. Then cylinder can be filled with liquid propane
    Vacuum Method where a vacuum is pulled on cylinder and then propane vapor is transferred in and then liquid propane can be pumped in.
    Should NOT need purging again UNLESS
    Service valve is replaced.....air in cylinder
  • downtheroad wrote:
    Just a brand new tank before the first fill.
    x2, unless it has been opened to the atmosphere.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
