Diamond_c
Nov 24, 2020Nomad
Propane tank
I’ve always wanted to know how your supposed to know how much propane is in your tank before it runs out?
Diamond c wrote:Get an automatic regulator that indicates when the primary cylinder is empty. With this system you will always know if you have more than half of total capacity and you are good to go. Or the indicator turns from green to red and you are less than half capacity and ready to fill one of the cylinders.
I have 2 tanks and manually switch from one to another when first one runs out. I was just looking to know how much the one that I’m on now has in it. We’re leaving tomorrow for a few days and I hate to get there and one run out as soon as we get there. The web site says that they sell propane but I had just rather not have to fool with it while we’re gone if I don’t have to.
So go top it off today
Then you have 2 full cylinders
Simple....
Veebyes wrote:
Your cooktop will show when tank level is getting low. Yellow flame. Your fridge may have a warning when the tank is getting low. Shaking the tank in place will tell you when it is getting low. Easy to tell a full one from an empty one. The tone of a tank when given a tap will let you know which is empty & which is full.
I don't use the automatic switchover on the regulator. I like to do it manually. When one goes empty, switch & refill at earliest opportunity. Less chance of forgetting till all out that way.
