Old-Biscuit
Aug 12, 2019Explorer III
cavie wrote:
YES, will run cheaper (If you paying for electric)and get colder than AC. Move the thermister down on the fins when on Gas.
Why do you want OP to move thermistor?
Thermostat controls heat cycles regardless of heat source based on feedback from thermistor.
On fridge WITH temp settings on upper panel.thermostat is calibrated for temp sensing from thermistor on a specific FIN position
On fridges with "AUTO TEMP CONTROL" (NO temp set points)
Moving it DOWN means warmer
Moving it UP means Cooler
Overall temp effect is 4-6*F
Propane & electric transfer basically same temp to boiler section
Propane does 'start' the process sooner due to hot flame
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
