valhalla360
Jan 14, 2020Navigator
avarusbrightfyre wrote:Eric&Lisa wrote:
Electric when on-grid (pay per night camping). Propane when off-grid dry camping.
If you are running on a meter, then it becomes a math problem. Electrical: Wattage of heater, hours run per day, cost of a kilowatt/hr, determine a dollar amount for daily usage. Propane: Cost to fill the tanks, estimated days per tank, determine a dollar amount for daily usage. One will be cheaper. My bet is on electric will be cheaper.
Ultimately you need to plug in the numbers and do the math. It will be different for all of us.
-Eric
Ok, so I need to make sure I'm doing my math right. Most of the space heaters I'm seeing are 1500 watts. I estimate 6 hours per day (cutting on an off from 6 pm to 6 am). It might be less, but I'm not sure. 1500 watts x 6 hours = 9 kwh. Current price per kwh for electric is $0.28, which puts me at about $2.52 per day, or $35 for two weeks.
My average price to fill a tank is about $18 every 10 days or so, or about $25 per 2 weeks, so it appears on the surface that propane is cheaper.
I guess now the question is am I willing to spend $20 per month for the convenience of not having to cart the tank around every 10 days. My first guess is probably yes, lol.
Assuming, you are getting the same level of heating...you have it figured out. Propane is typically a bit cheaper but there is a convenience of electricity just showing up at the pedestal for as long as you want it.
If electricity is not metered, obviously, use electric.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
