Desert_Captain
Jan 15, 2020Explorer III
We have a large {35,000 BTU}, very efficient, LP furnace in our 24' Class C. When the temperature differential is in the 40 degree range {between 32 ambient and 72 in the coach} the furnace runs for about 5 minutes every hour. Any electric heater is going to run virtually all of the time. Keep in mind that our coach {Nexus} is very well built, vacuum sealed multilayer walls, Azdell and has heated tanks.
Propane is far more efficient and the cost differential is minimal but... as noted if they are not metering your electric go for it. I usually use the AC to heat our water even if metered as it is on very little as the tanks maintains the heat well.
:C
:C
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
