pmlevine's avatar
pmlevine
Proper Protocol for “Complimentary Roof Inspection”
What is the proper protocol an RV Service Center should follow when offering their customers a “Complimentary Roof Inspection” ? I dropped off my 2016 TT (rubber roof with Dicor seam sealant) in for routine maintenance. I was informed the sealant on the roof needed to be redone - removed and new sealant applied - at a cost of $1300. The RV Service Center sent me photos which showed 2 large holes in sealant areas. I had cleaned the roof in late fall and had the TT covered over the winter, and there were no holes in the sealant.
I declined the $1300 repair, took the TT home, went topside to inspect the sealant holes. It appears there are a few soft raised “bubbles” of sealant, these can be pressed down with slight pressure, but bounce back up.
Is it proper procedure for an RV Service Center have a technician, as part of a “Complimentary Roof Inspection” dig into an otherwise intact soft spot of sealant, creating a hole in the sealant ? I requested the RV Service Center perform a patch job on the few affected areas, but they refused, saying this would not be a good repair option. This is a 3 year old TT, and I believe I can selectively remove the few areas of soft sealant with Dicor self-leveling sealant myself.
Thanks for any advice.
  • But some 4" Eternabond tape and seal over all of your joints and sealant. Follow the directions and you won't have to worry about failed sealant again. I did this to both of our FW's and in five years haven't had to touch it.
  • Don't be taking your rig back to them ever. You have seen how they are dishonest, don't give them another chance at anything.
  • That is a scam / ripoff! Run away from that dealer
  • Three years old? $1300? OMG. Clean the bad areas and use self leveling Dicor
  • Definitely learn to do it yourself. It's not difficult and you will save a lot of money.
    I would not want the dealer putting someone on my roof to do an inspection by digging in the caulking. The 'Tech' may not be as experienced and professional as you think.
    Search Youtube for repair videos, you will find several.
    You may also want to find a new RV Service Center.
  • There’s no complementary, it’s just like a car dealership doing a “free 38 point inspection”; it’s a chance to find something to repair and charge you. They WILL find something and like you suspect, they’ll even make sure you have damage so they can get your money. Buy some Dicor lap sealant and do the easy job yourself-$12.00
    Learn to do all your maintenance yourself and you’ll be a much happier camper!
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
