TexasChaps
Oct 31, 2016Explorer
Tumbleweed13 wrote:
I'm curious as to what you consider the correct psi, to put into your trailer tires? I have a toy hauler, 28' twin axle. Fully loaded i'm 15 - 16K lbs. The max rating on the tires, is stated at 80psi. I've always pumped them up, to 75psi. Giving me a bit of room for pressure increase, due to heat.
What do you guys think?
I have a buddy, that has a very similar set up, and he only runs 50psi. His tires have the same max psi as mine. Is this ok too?
That are your thoughts on this?
Thanks, Joe
I run at max cold pressure as stated on the sidewall.. never had a problem.. ever..
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
