mike-s
Oct 31, 2016Explorer II
theoldwizard1 wrote:Maybe, if the original spec tires are installed, and the camper is loaded near its load capacity. If the max load calls for a LR B tire (35 PSI), but LR C (60 PSI) tires were installed, inflating to the max is probably not the thing to do. It will cause a harsher ride. A LR C tire at 40-50 PSI can provide a compromise between more load capability (margin/safety/longevity/reliability, which can be a separate argument) and an overly harsh ride.TexasChaps wrote:
I run at max cold pressure as stated on the sidewall.. never had a problem.. ever..
Correct !
Car and truck tires are frequently specified at less than their max load pressure, simply because the max load isn't needed.
And, some TTs may be similar - the tire/pressure label is what to go by, not what's marked on the tire sidewall.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
