goducks10
Nov 01, 2016Explorer
I've always ran my TT tires to the max psi on the tire which was the same as the TT's tire sticker. I now had E instead of D rated tires on. I run them lower than the max psi of 80 because they have a higher weight rating. You need to run the tire at whatever psi is applicable to it's load.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
