TexasChaps
Nov 01, 2016Explorer
mike-s wrote:theoldwizard1 wrote:Maybe, if the original spec tires are installed, and the camper is loaded near its load capacity. If the max load calls for a LR B tire (35 PSI), but LR C (60 PSI) tires were installed, inflating to the max is probably not the thing to do. It will cause a harsher ride. A LR C tire at 40-50 PSI can provide a compromise between more load capability (margin/safety/longevity/reliability, which can be a separate argument) and an overly harsh ride.TexasChaps wrote:
I run at max cold pressure as stated on the sidewall.. never had a problem.. ever..
Correct !
Car and truck tires are frequently specified at less than their max load pressure, simply because the max load isn't needed.
And, some TTs may be similar - the tire/pressure label is what to go by, not what's marked on the tire sidewall.
quite right, but you will find that most OEM specified trailer tires are marginal at best.. hence all the talk of upgrading to larger sizes and or LT tires.. my TT for example has the same pressure on the sticker as the tire.. so on stock tires I would prefer a "harsher" ride than under inflated tires..
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
