ktmrfs
Nov 01, 2016Explorer III
Turtle n Peeps wrote:mike-s wrote:
Tire and loading sticker on the left side, in front near the bottom.
PSI is cold pressure, if it calls for 80 PSI, put 80 PSI in when cold. 75 PSI would be underinflated. The given pressures already take into account any pressure increase from heat.
This ^^^^^. I personally run max or even max +10. In 40 years I had one blow out.
Ditto, with the comment this is what I do for my TRAILER. TV and cars trucks etc. run what the mfg recomends.
In fact many of the trailer tire mfg. state the tires are designed to be run at max inflation pressure regardless of load.
And I do that even though the load capacity at max pressure is much higher than the actual load. and the tires still wear very evenly.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
