ktmrfs
Nov 01, 2016Explorer III
mowermech wrote:
You can always try the "chalk test" to find the CORRECT tire inflation.
Make a chalk mark or two (or more) across the tread of the tire. Drive a few yards on a hard surface, then look at the chalk mark(s).
If the chalk mark(s) are worn off evenly across the tread, the inflation is just right for the present load.
If the chalk mark(s) are worn only on the sides of the tread, the tires are under-inflated for the load. Add air.
If the chalk mark(s) are worn only in the center of the tread, the tires are over-inflated. Remove air.
For best traction in braking and turns, the contact patch between the tire and road must be as large as possible. Over or under inflation reduces the size of that contact patch, and wears the tread unevenly.
I'll disagree with contact patch related to pressure. the info on using chalk to see if your near correct on inflation is a common tool, well characterized.
contact patch area is very linearly related to pressure once you've got a reasonable pressure in the tire. contact patch area in square inches will be very close to the weight the tire is supporting divided by the tire pressure in psi. Contact patch SHAPE is highly dependent on the aspect ratio of the tire.
At very low pressure it is not linear because your also then dealing with the sidewall stiffness in the equation.
High inflation reduces the area of the contact patch while low inflation increase the area of the contact patch for a given load. The shape will change as well.
the shape and area change both change traction characteristics along with the effects of sidewall deformation with lateral load with varying pressure.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
