mike-s
Nov 01, 2016Explorer II
ktmrfs wrote:Citation? Because, Goodyear says this:
In fact many of the trailer tire mfg. state the tires are designed to be run at max inflation pressure regardless of load
Since RVs can be loaded with many different configurations, the load on each tire will vary. For this reason, actual air pressure required should be determined based on the load on each individual tire....and backs it up by publishing load/inflation tables which show pressures less than the max for a load range.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
