deltabravo
Nov 02, 2016Nomad
Tumbleweed13 wrote:
I'm curious as to what you consider the correct psi, to put into your trailer tires? I have a toy hauler, 28' twin axle. Fully loaded i'm 15 - 16K lbs. The max rating on the tires, is stated at 80psi. I've always pumped them up, to 75psi. Giving me a bit of room for pressure increase, due to heat.
What do you guys think?
Run them at 80 PSI. You don't need to run lower PSI to allow for heat expansion. The tires are always marked with a pressure, followed by the letters "PSI COLD"
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
