- AH64IDExplorerST tires and car/truck tires are different, but there ARE load/inflation tables specifically for ST tires.
Stating one Should inflate to max sidewall pressure is a technique, but it is NOT the one recommended by the tire manufacturer or most trailer companies (at least every manual I have looked at says to adjust trailer tire pressure for the load). The one recommendation that should matter is the one by the tire manufacturers.
I have lots and lots of miles with ST's at proper pressure, not max, at sustained speeds up to 70-72 and have never had a neat related failure in 20 years of dragging trailers. Some trailer where at, or slightly above, load capacity and some where well under.
The OP asked for proper pressure not how to run them overinflated as most have recommended.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf - Campfire_TimeExplorer
LarryJM wrote:
Ranger Smith wrote:
There are at least 100 topics on this. It has to do with the weight on each axle and tire . . . Do a searchfrankdamp wrote:
Do NOT use the max pressure molded into the sidewall. That's the maximum the tire can take without blowing up (with a safety factor, of course). You need to weigh the load on the tires (when typically loaded for a trip), then consult the tire manufacturer's load/pressure chart.
As an example, the tires on my Kia minivan are rated to 45 psi by the molded # on the sidewall. The vehicle manufacturer recommends 34 in the front and 38 in the back. With our typical load (me, DW and our two Labradors) the weighbridge numbers suggest 31 front and 35 rear. The Toyos I have on the van are at about 55,000 miles (van has 120K) and are still in good shape, using those numbers.
Both of the above quotes are IMO WRONG for ST tires which is what was asked about. While using pressures based on load inflation for normal vehicles has merit, tires on trailers and especially ST tires should be inflated to the max pressure listed on the sidewall as almost all of the other posts in this thread so far have recommended.
Larry
X2! Thank you Larry for clarifying this. ST tires and car tires are two different animals altogether. - Chris_BryantExplorer IIAnother vote for sidewall pressure for the reasons Larry and others have given.
I'm probably one of the few people who has worn out trailer tires @ 90,000 miles. - LarryJMExplorer II
Larry - myredracerExplorer IIRun them at exactly what the "maximum" on the sidewall says.
I posted this in another thread:
Tires should be cold inflated to the tire's max. sidewall pressure in the morning before heading off or after at least 3 hours of sitting in full shade. Don't go by the placard figure. The tires may have been upgraded by an owner or the factory. We have factory optional LRD tires that should be run at 65 psi however the factory used their standard placard for LRC tires (50 psi). Using the placard psi in our case would result in serious damage and a blowout(s).
The term "maximum" used on the sidewall tires creates confusion. It is actually the temp. that the tire should be cold inflated to in order to carry the load rating indicated on the sidewall. Lowering the pressure can result in overloaded tires (not good).
Cold inflation pressure is the inflation pressure taken with tires at the prevailing atmospheric temperatures. Tire pressure only changes about 2% for every 10F change in temp. Running your tires low will damage them from overheating and is a good invitation for an eventual blowout. You should never bleed them down when they are hot. Tires are designed and tested to be able to withstand up to around 3 times the sidewall pressure so no worries about exploding tires from running in high ambient temps.
For some tires (only a couple I think) such as GY Marathons, you can raise the psi by 10 psi and be able to run at 75 mph max.
Go and google "RVtiresafety" and you will find your answer there. Lots of reading on anything you ever wanted to know about RV tires. Remember, ST trailer tires are more "delicate" in comparison to other tire types and you want to take all the recommended measures to take care of them to minimize premature wear and reduce the chances of a blowout. Heat is the biggest enemy of ST tires by under-inflating and/or running above 65 mph. - coolbreeze01Explorer
Beerdawg wrote:
What should the proper tire pressure be on ST205/75R15 tires on a travel trailer? Thanks
Max psi per the sidewall, will allow your tires to perform their best. Low psi builds heat and heat kills tires. - AH64IDExplorerI have yet to see a trailer with recommended pressure on a sticker, but every trailer tells you max pressure at max load.
Tire manufacturers publish load/inflation charts for a reason, proper pressure is the pressure at which the tire can support the load applied.
Overinflated isn't as bad as underinflated but still has drawbacks such as decreased traction, decreased tread life, increased susceptibility to road hazards, and transfer more road imperfections to the trailer.
The correct answer to weigh your axles and adjust accordingly. 5 psi over chart pressure is also recommended, up to sidewall max, if you will be driving 60-65 for a long ways. Until you can weigh your trailer run max pressure, but do weigh it. - frankdampExplorerDo NOT use the max pressure molded into the sidewall. That's the maximum the tire can take without blowing up (with a safety factor, of course). You need to weigh the load on the tires (when typically loaded for a trip), then consult the tire manufacturer's load/pressure chart.
As an example, the tires on my Kia minivan are rated to 45 psi by the molded # on the sidewall. The vehicle manufacturer recommends 34 in the front and 38 in the back. With our typical load (me, DW and our two Labradors) the weighbridge numbers suggest 31 front and 35 rear. The Toyos I have on the van are at about 55,000 miles (van has 120K) and are still in good shape, using those numbers. - LaurenExplorerMax at stated on the tire.
- JIMNLINExplorer IIIIf their close to the OEM capacity and close to the trailers OEM axle capacity I would run max pressures.
Close spaced axles toward the center of the trailer places tremendous side loads on the tires as they slide sideways while going around corners. Just one of many good reasons to use max pressures.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
