jefffoxsr
Apr 13, 2017Explorer
Proper tire pressure for load range E 10 ply tires
I bought some new tires today.
Load Range E (10 ply). Cooper Discoverer AT3.
I will not tow with this 2015 Ford F150 but the 35 x 12.50 x 20 tire size only comes in a load range E.
I requested to put the tires at 35# since I am not towing.
The owner of the tire business said that although I am not towing that load range E tires absolutely MUST be run at no less than 50 psi. He said the reason was that the tire will not function correctly, the truck will not ride correctly, the side wall of the tire will break down, and the there will be cupping of the tire.
If this is generally true from a technical standpoint and design standpoint then I will run them at 50 psi. If I can safely run them at 35 psi and have the tire function correctly and ride properly then please let me know.
Thank you very much for your technical assistance and your experience. Take care. :)
