- phaysExplorerI saw an audio/visual presentation where the presenter used his IR temp gun as a laser pointer. Who knew you could measure temperature with one of these things?
- NaioExplorer III bought one because of you guys :).
Used it yesterday to check my laundry dryer to see if thermostat was working now. Clothes at 143 degrees -- just perfect! - GjacExplorer IIII bought mine to check for radiator blockage when I was having overheating problems. So far so good radiator is 20 years old with no blockage.
- jmckelvyExplorerOne of my sons uses his to measure the temperature of oil in a skillet when he fries something.
- kellertx5erExplorerI bought mine to keep tabs on wheel/hub temps; this info is like getting a 'two-fer.'
- samhain7ExplorerAwesome post.
- rexlionExplorerI couple of degrees lower, and it would have been ice cold. ;)
- 3oaksExplorer
Bumpyroad wrote:
If mine reaches 41', I'm not drinking fast enough! :B
I thought the proper temperature was 41 degrees.
bumpy - raygregExplorerWould you believe that it works on vodka tonic and margaritas too!!
- TUBE_PULLERExplorer:C
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
