Mvander's avatar
Mvander
PSI question
Hi Everyone. Looking for an answer/opinion on the following. I swapped out my trailer tires this week and up-gradded to a load range C from a B that were the original tires. I havent pulled the TT around much with the new tires but it seemed to be a little more "bouncy". The previous tires were Marathons with a max 35psi. The replacements are Hercules Power STR max 50psi.
Now to the question. Would it be OK to run the new tires at a bit less PSI to "smooth out" the ride or should I just live with a bit more "bounce"?
Trailer is 5450# gross
New tires are 1760# @50PSI
Old tires were ????# @35PSI
All size 205/75/14
No other changes to the rig set-up
Thanks in advance for any input. I'm going to give it a good tow this week-end before I make any changes but your opinions would be great.
  • heat is a tire killer
    running at 50 psi your tires will actually run cooler than at 35 psi.
    the rated load capacity of your tires is at 50 psi
    if you run 35 psi then the load capacity is lower .
    i upgraded my boat trailer tires from 13 inch to 14 inch .
    my boat trailer is a little more bouncy but i do not care because nobody is riding in my boat going down the highway .
    i tow my boat long distances in the summer , sometimes in 100 degree heat .
    i upgraded because i wanted no problems getting to the lakes, rivers , and the delta .
    i run the max inflation pressure listed on the sidewall .
    regarding jacknifing i have owned many trailers , all types .
    the principal cause of jacknifing is the trailers that have too short a difference between the trailer axles and the trailer ball .
    i have owned 8 different boats since 1972 .
    the remedy for jacknifing is moving the axle rearward .
    my current boat trailer , i moved the axles back a foot .
    my trailer will not sway even if i am going too fast down a 7 % grade in a curve with a pepsi in one hand and a sandwich in the other ...........
  • K Charles wrote:
    If the tires have 1760 lb on them you should run 50 PSI, if less weight then you could run less PSI.
    Over inflated tires will wear faster, have less traction for braking, and are more liable to cause trailer jackknifing. Obviously the ride suffers, and potential damage due to potholes increases.
    If you tell us the ACTUAL weight on each wheel when fully loaded we can then tell you what psi would be recommended by many manufacturers.
    For example I have a little single axle TT with ST205/75R15's on it. When fully loaded, as we use it, it weighs 1580#. The tongue weight is 200#, so assuming equal loading there is 690# on each tire. Normal DESIGNER recommended psi of 15 psi will handle a load of 905#.
    Does anybody think I should really inflated to 50 psi? If I do so the trailer will jackknife in a heartbeat.
    I actally run 20 psi, 15 is a bit too low for my comfort, but I'm sure not running 50 psi. It would be like running solid steel wheels with no tires. Ever ride in an old buckboard?
  • Life on the tire is easiest if you air it up to its max.
  • If the tires have 1760 lb on them you should run 50 PSI, if less weight then you could run less PSI.
  • I"d leave the air pressure up and work on the WD hitch set up to address bouncy towing. Improperly adjusted or improperly sized spring bars will certainly cause a porpoises effect.
  • Ron3rd wrote:
    the B tires where only marginally suited for the trailer.
    My thought exactly. When I was shopping/pricing tires I didn't even come across B range tires in that size. I feel better knowing theres a bit more saftey margin built in now.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I had the exact same tires as you on my old trailer and you want to keep them inflated to the max psi on the sidewall which is 50 psi in your case. BTW, my old trailer came with load range B and when 2 of them blew, Discount Tire set me up with load range C. IMO, the B tires where only marginally suited for the trailer.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
