stro1965
Nov 25, 2015Explorer
Pull battery for winter?
So can I, or should I not, leave my battery in and leave the camper plugged in through a Nebraska winter? I can't seem to find a definitive answer if it will hurt anything?
stetwood wrote:But are the alarms-propane and CO interrupted by a fuse or circuit breaker? Every one I've seen are always connected straight to the DC source, i.e. the battery.Trackrig wrote:Never that cold, but -20 or more most winters and never pulled batteries from tractors. I did learn the hard way though with the camper to pull the fuses and shut off the breakers. Radios, TVS and warning lights will draw power.
Up by Fairbanks I've had batteries last eight years and they sat in the rig every winter down to -60. If you don't have battery disconnect switch that kills absolutely EVERYTHING, then disconnect the battery cables and they should be fine.
Bill
