stro1965
Nov 25, 2015Explorer
Pull battery for winter?
So can I, or should I not, leave my battery in and leave the camper plugged in through a Nebraska winter? I can't seem to find a definitive answer if it will hurt anything?
westend wrote:As would the built in converter. Top off the battery water, plug it in and forget it.stetwood wrote:But are the alarms-propane and CO interrupted by a fuse or circuit breaker? Every one I've seen are always connected straight to the DC source, i.e. the battery.Trackrig wrote:Never that cold, but -20 or more most winters and never pulled batteries from tractors. I did learn the hard way though with the camper to pull the fuses and shut off the breakers. Radios, TVS and warning lights will draw power.
Up by Fairbanks I've had batteries last eight years and they sat in the rig every winter down to -60. If you don't have battery disconnect switch that kills absolutely EVERYTHING, then disconnect the battery cables and they should be fine.
Bill
Another aspect of this is--What is the optimum for battery longevity and is that important to the user? Most battery information states that having a float charge on a stored battery will increase it's life and result in less loss of capacity. Does it matter if your RV battery lasts 2-4 or more years than if left on it's own over the Winter? Will a user be OK with a loss of amp hour storage over subsequent storage periods?
I have 5 batteries in my RV, at present. and I plan to add two more. To me, battery longevity is important and I'd like to lose no capacity. Fortunately, my solar system does a great job of keeping everything charged while in storage.
For a user without a solar charging system, a float charger would accomplish the same task.
