mikebol
May 15, 2018Explorer
Pullrite SuperGlide with RAM OE Pucks
Hey gang!
I have a Pullrite 4100 SuperGlide out of my 2007 RAM and would like to use this with my new-to-me 2016 RAM with the OE 5th wheel prep puck system. Both trucks are short beds, 6'4". Talking to Pullrite, I need two parts from them to support the pucks but the combination raises the hitch 5" and I'm already feeling chucking in the setup as it exists today. My fear is that raising it up even further is going to create even more flex and chucking.
My question...
For those of you that may have moved from a Pullrite rail kit to the OE pucks, did you find a base plate that by luck might line up or work with the SuperGlide without adding 5" of height and another 60#s of steel? I already have to use a hoist to get this monster in\out of the truck bed.
For the cost I'm seeing for this adaptation, I can go pick up a SuperLite or Anderson for the same money. The only concern I have is obviously clearance to the cab corners. I have an Outback 325FRE and the corners are only slightly rounded.
Thanks for any insights.
Mike
My question...
Mike
