Yosemitebobr
Dec 11, 2015Explorer
I found my paperwork for the water pump. It's an ARTIS Model #PDS1-130-1240E
that is all that is on my paperwork
Artis PDSI-130-124 Fresh Water Pump 40PSI
The Artis delivers steady and reliable water pressure for the entire RV. Delivering steady flow up to 3.0 GPM, giving you good working pressure along with great reliability. One of the safety features are thermal and over pressure protection, as well as the pumps capability to run dry with no damage. The Artis has been tested and approved by Underwriters Laboratories (UL) to meet both the US and Canadian standards. ARTIS has engineered patented four-chamber design, which improves efficiency while maintaining stable water flow. The ARTIS self-priming feature allows a suction lift up to 6 feet. It has been designed for easy installation and trouble-free operation. In addition to the pump it self, ARTIS strainers are built to keep your tank protected from harmful debris. An integral o-ring creates a tight seal, eliminating possible leaks. The Artis is a quiet UL-Listed RV potable water pump with patented diaphragm design.
12 Volt DC Service Setup:
- Self-priming to 6-feet suction
- Pump able to run dry without damage
Your Price : $62.80
Item Number : N10-0073
Manufacturer : Artis
Manufacturer Part No : PDSI-130-124
Your Price : $62.80
