dw1gator's avatar
dw1gator
Question about Even Brake system
Not familiar with this. It says you plug into your vehicle charge station. But if you have pulled your fuse to prevent dead battery, how does this work with the braking system? Thanks
  • wildtoad wrote:
    What car are you talking about? On my Chevy Sonic I have to pull/disable the DSLI fuse, but the car still starts, runs, etc. The 12v plug where I plug mine into still operates when I turn the key as described in the towing section of my Chevy manual.
    I might have it figured out. #8 is my ignition switch fuse. So I am disabling the ignition swith because it is switched on for steering but my charge station should still be good, right?
    2010 Chevy HHR. Says I need to pull the #8 fuse to prevent dead battery? Been researching but this towing a vehicle is still all new to me.
  • What car are you talking about? On my Chevy Sonic I have to pull/disable the DSLI fuse, but the car still starts, runs, etc. The 12v plug where I plug mine into still operates when I turn the key as described in the towing section of my Chevy manual.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
